| Configuration | Part No. | Input power |
| with full CNC control | 084008 | 200V, 50-60 Hz, 3Ø |
| 084027 | 208V, 60 Hz, 3Ø | |
| 084028 | 240V, 60 Hz, 3Ø | |
| 084009 | 400V, 50 Hz, 3Ø | |
| 084021 | 440V, 60 Hz, 3Ø | |
| 084010 | 480V, 60 Hz, 3Ø | |
| 084011 | 600V, 60 Hz, 3Ø | |
| with full CNC control & Voltage Divider Board | 084013 | 200V, 50-60 Hz, 3Ø |
| 084029 | 208V, 60 Hz, 3Ø | |
| 084030 | 240V, 60 Hz, 3Ø | |
| 084014 | 400V, 50 Hz, 3Ø | |
| 084023 | 440V, 60 Hz, 3Ø | |
| 084015 | 480V, 60 Hz, 3Ø | |
| 084016 | 600V, 60 Hz, 3Ø | |
| with Control Panel SA for current control | 084000 | 200V, 50-60 Hz, 3Ø |
| 084025 | 208V, 60 Hz, 3Ø | |
| 084026 | 240V, 60 Hz, 3Ø | |
| 084004 | 400V, 50 Hz, 3Ø | |
| 084022 | 440V, 60 Hz, 3Ø | |
| 084005 | 480V, 60 Hz, 3Ø | |
| 084012 | 600V, 60 Hz, 3Ø | |
| with Control Panel SA for current control & Voltage Divider Board | 084017 | 200V, 50-60 Hz, 3Ø |
| 084031 | 208V, 60 Hz, 3Ø | |
| 084032 | 240V, 60 Hz, 3Ø | |
| 084018 | 400V, 50 Hz, 3Ø | |
| 084024 | 440V, 60 Hz, 3Ø | |
| 084019 | 480V, 60 Hz, 3Ø | |
| 084020 | 600V, 60 Hz, 3Ø |
Operator and instruction manuals (2)
Showing 2 of 2 documents
Specifications
Power supply
| Electrical Rated OCV Output Current Output voltage Duty Cycle at 40 C Input Voltage |
235 VCD at rated input voltage 4 - 19 amps, adjustable in 1-amp increments 120 VCD 100% (19 amps, 120 VCD) 200 V, 3 PH, 50-60 Hz 208 V, 3 PH, 60 Hz 240 V, 3 PH, 60 Hz 400 V, 3 PH, 50-60 Hz 440 V, 3 PH, 60 Hz 480 V, 3 PH, 60 Hz 600 V, 3 PH, 50-60 Hz |
| Dimensions and Weight Depth Width Height Weight |
716 mm (28.2 inches) 321 mm (12.6 inches) 475 mm (18.7 inches) 55 kg (100 pounds) |
| Gas Requirements Plasma Gas Shield |
Air or H5 (premixed industrial grade gas containing 5% Hydrogen and 95% Argon) Air |
| Gas Quality Air H5 |
Clean, dry and oil-free 5% Hydrogen, 95% Argon premixed |
| Flow Rates and Pressures Plasma Gas Shield Plasma |
28 I/min (60 scfh) @ 6.9 bar (100 psi) supplied to power supply pressure regulator 141 I/min (300 scfh) @ 6.9 bar (100 psi) supplied to power supply pressure regulator |
Plasma torch
| Type | Dual Gas, Mechanized |
| Gas | Plasma and Shield (refer to gas requirements) |
| Starting Method | Contact start |
| Cap Sensor | Pneumatic |
| Dimensions and Weight Diameter Length Weight |
38.1 mm (1.5 inches) 280 mm (11 inches) 0.8 kg (1.5 pounds) |
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Power supply configurations
Power supplies - cover, front and rear
| Index No. | Ref. Desig. | Part No. | Description | Quantity |
| 1 | 001582 | Cover, ArcWriter Power Unit | 1 | |
| 2 | 001446 | Foot, MAX70 Power Unit | 4 | |
| 3 | 001580 | Base, ArcWriter Power Unit | 1 | |
| 4A | M1 | 031116 | Fan, 100-115 scfm 120 VAC/50-60 | 1 |
| 4B | 027494 | Filter, used with fan 031116 (4A) | 1 | |
| 5 L | LT1, LT3 | 009382 | Light, Pilot, Green LED 24 VAC 187 QDisc | 2 |
| 6 | LT2 | 009375 | Light, Pilot, Yellow LED 24 VAC 187 QDisc | 1 |
| 7A | 129096 | Control Panel Subassembly (see Fig. 6-4) | 1 | |
| 7B | 001594 | Panel, Cover (used in place of control panel assy) | 1 | |
| 8 | 008310 | Receptacle, CPC 23-19 Reverse Sex | 1 | |
| 9 | 008279 | Strain Relief | 1 | |
| 10 | 008482 | Strain Relief, 1-1/4 NPS Basket | 1 | |
| 11 | CT1 | 027274 | Counter, Self Powered LCD | 1 |
| 12 | CT2 | 027275 | Meter, Self Powered Elasped Time | 1 |
| 13A* | CB1 | 003187 | Circuit Breaker, 3 Pole, 15A | 1 |
| 13B** | 001636 | Cover, circuit breaker (600Vunits only) | 1 | |
| 14 | 008228 | Cord Grip, 1-1/4 NPT .850 -1.320 2SC | 1 | |
| 129071 | Gas SA, Shield/Cap Sensor | 1 | ||
| 15 | 011039 | Filter/Regulator, 0-120 PSI 1/8 NPT Gas | 1 | |
| 16 | 011054 | Filter Element | 1 | |
| 17 | 015152 | Nipple, Quick Connect, Steel, 1/8 NPT (mount on regulator, part of consumable parts kit) | 1 | |
| 18 | 022019 | Gauge, Pressure 0-100 PSI 1-1/2" | 1 | |
| 19 | S1 | 005044 | Switch, Toggle SPDT Maint ON/NONE/ON | 1 |
| 129072 | Gas SA, Plasma | 1 | ||
| 20 | 022027 | Gauge, Pressure 160 PSI 1-1/2" | 1 | |
| 21 | 011080 | Regulator, 0-120 PSIG 1/4 FPT w/Knob | 1 | |
| 22 | 015152 | Nipple, Quick Connect, Steel, 1/8 FPT (mount on regulator, part of consumable parts kit) | 1 |
** Used on 600V power supplies only.
Power supplies - left side
| 1 | A3 | 129147 | Chopper SA, ArcWriter | 1 |
| 2 | T3 | 014162 | Transformer, 24 VCT, 0.25A, 120 VAC Power | 1 |
| 3A | M1 | 031116 | Fan, 100-115 scfm 120 VAC/50-60 | 1 |
| 3B | 027494 | Filter, used with fan 031116 (4A) | 1 | |
| 4 | 008482 | Strain Relief, 1-1/4 NPS Basket | 1 | |
| 5 | 009295 | Capacitor, 2500 µf 25WV-10-+50% CMPTRGR | 1 | |
| 6 | L1 | 014202 | Inductor, 15 MH | 1 |
| 7 | T1 | 129131 | Transformer SA, 200V Unit | 1 |
| 129220 | Transformer SA, 208V Unit | 1 | ||
| 129130 | Transformer SA, 240V Unit | 1 | ||
| 129129 | Transformer SA, 400V CE Unit | 1 | ||
| 129219 | Transformer SA, 440V Unit | 1 | ||
| 129128 | Transformer SA, 480V Unit | 1 | ||
| 129218 | Transformer SA, 600V Unit | 1 | ||
| 8 | 011039 | Filter/Regulator, 0-120 PSI 1/8 NPT Gas | 1 | |
| 9 | 011054 | Filter Element | 1 | |
| 10 | 022019 | Gauge, Pressure 0-100 PSI 1-1/2" | 1 | |
| 11 | 123107 | Cord, Power 15 feet, All Units Except 400V CE | 1 | |
| 123154 | Cord, Power 15 feet, 400V CE Units | 1 | ||
| 12 | 011080 | Regulator, 0-120 PSIG 1/4 FPT w/Knob | 1 | |
| 13A* | CB1 | 003194 | Circuit Breaker, 3 Pole, 15A | 1 |
| 14*** | 041542 | PC BD Assy, CE Filter (400V units only) | 1 | |
| 15** | TB2 | 008933 | Board, 3-Terminal (600Vunits only) | 1 |
| 16 | CON1 | 003212 | Contactor: 3 Phase with AC Coil | 1 |
| 17 | F1, F2 | 108017 | Fuse, 1/2A 600V 13/32 X 1-1/2 TD, 200V, 208V and 240V Units | 2 |
| 108005**** | Fuse, 1/4A 600V 13/32 X 1-1/2 TD, 400V, 440V, 480V and 600V Units | 2 | ||
| 18 | T2 | 129126 | Transformer, Control SA 200V Unit | 1 |
| 129217 | Transformer, Control SA 208V Unit | 1 | ||
| 129127 | Transformer, Control SA 240V Unit | 1 | ||
| 129124 | Transformer, Control SA 400V CE Unit | 1 | ||
| 129216 | Transformer, Control SA 440V Unit | 1 | ||
| 129125 | Transformer, Control SA 480V Unit | 1 | ||
| 129215 | Transformer, Control SA 600V Unit | 1 |
*** Used on 400V CE power supplies only.
**** On 400V CE units, only order listed fuses or European equivalent fuses as replacements.
Power supplies - right side
| 1 | SV1 | 006095 | Valve, Solenoid, 1/8 FPT 120V 2WNC | 1 |
| 2 | PS1 | 005112 | Switch, Pressure 39 PSI .013 Orifice | 1 |
| 3 | 011080 | Regulator, 0-120 PSIG 1/4 FPT w/Knob | 1 | |
| 4 | 022027 | Gauge, Pressure 160 PSI 1-1/2" | 1 | |
| 5 | CS1 | 009373 | Sensor, Current 40-200A/HD | 1 |
| 6 | 011039 | Filter/Regulator, 0-120 PSI 1/8 NPT Gas | 1 | |
| 7 | 011054 | Filter Element | 1 | |
| 8 | SV2 | 006095 | Valve, Solenoid, 1/8 FPT 120V 2WNC | 1 |
| 9 | PS2 | 005112 | Switch, Pressure 39 PSI .013 Orifice | 1 |
| 10 | 007035 | Shunt, 20A 100MV | 1 | |
| 11 | 009438 | Resistor, 5-Ohm 50W 5% wire wound | 1 | |
| 12 | 003021 | Relay, 120VAC SPST NO | 1 | |
| 13 | A1 | 041516 | PC BD Assy, Control | 1 |
| 14 | 008482 | Strain Relief, 1-1/4 NPS Basket | 1 | |
| 15 | 008310 | Receptacle, CPC 23-19 Reverse Sex | 1 | |
| 16 | LT2 | 009375 | Light, Pilot, Yellow LED 24 VAC 187 QDisc | 1 |
| 17 | LT1, LT2 | 009382 | Light, Pilot, Green LED 24 VAC 187 QDisc | 2 |
| 18 | A4 | 041513 | PC BD Assy, Power Distribution | 1 |
| 19 | F3, F4 | 008818* | Fuse, MDL 3/4 amp | 2 |
| 20 | 003096 | Relay, 24 VAC DPDTBifurcated Cont | 2 | |
| 21 | TB1 | 008933 | Board, Terminal 3-Terminal Fu-HDS w/Prot | 1 |
| 22 | A2 | 041377 | PC BD Assy, Voltage Divider (can be purchased for customer supplied THC units) | 1 |
** Used on 400V CE units only.
Control panel subassembly (129096)
| 1 | PB1 | 005201 | Switch, pushbutton, momentary NO | 1 |
| 2 | PB2 | 005203 | Switch, pushbutton, momentary NO | 1 |
| 3 | S3 | 005193 | Switch, Thumbwheel Assembly | 1 |
Upgrades
Powermax45 XP plasma cutter
The Powermax45® XP 45-amp plasma power supply was last manufactured in March 2024, and is no longer available for sale from Hypertherm. We continue to make original replacement torches, consumables, and repair parts.
Field service bulletins (4)
Showing 4 of 4 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
