Service manuals (2)
Showing 2 of 2 documents
Showing of 2 documents
Application notes (1)
Showing 1 of 1 documents
Showing of 1 documents
Specifications
Input voltages CSA 200–480 V, 1-PH, 50/60 Hz
200–600 V, 3-PH, 50/60 Hz
CE 380/400 V, 3-PH, 50/60 Hz
Input current @12.2 kW CSA 200/208/240/480 V, 1-PH, 70/68/58/29 A
200/208/240/480/600 V, 3-PH, 42/40/35/18/17 A
CE 380/400 V, 3-PH, 20.5/19.5 A
Output current 25–85 A
Rated output voltage 143 VDC
Duty cycle @ 40°C (104°F) CSA 60% @ 85 A, 230–600 V, 3-PH
60% @ 85 A, 480 V, 1-PH
50% @ 85 A, 240 V, 1-PH
50% @ 85 A, 200–208 V, 3-PH
40% @ 85 A, 200–208 V, 1-PH
100% @ 66 A, 230–600 V, 1/3-PH
CE 60% @ 85 A, 380/400 V, 3-PH
100% @ 66 A, 380/400 V, 3-PH
Open circuit voltage (OCV) CSA 305 VDC
CE 270 VDC
Dimensions with handles 500 mm (19.7") D; 234 mm (9.2") W; 455 mm (17.9") H
Weight with 7.6 m (25') torch CSA 32 kg (71 lbs.)
CE 28 kg (62 lbs.)
Gas supply Clean, dry, oil-free air or nitrogen
Recommended gas inlet
flow rate/pressure
Cutting: 189 l/min (400 scfh, 6.7 scfm) @ 5.9 bar (85 psi)
Gouging: 212 l/min (450 scfh, 7.5 scfm) @ 4.8 bar (70 psi)
Input power cable length 3 m (10')
Power supply type Inverter – IGBT
Engine drive rating System output current Performance (arc stretch)
20 kW 85 A Full
15 kW 70 A Limited
15 kW 60 A Full
12 kW 60 A Limited
12 kW 40 A Full
8 kW 40 A Limited
8 kW 30 A Full
Cut capacity
Capacity Thickness Cut speed
Cutting
Recommended 25 mm (1") 500 mm/min (20 ipm)
  32 mm (1-1/4") 250 mm/min (10 ipm)
Severance (hand cutting) 38 mm (1-1/2") 125 mm/min (5 ipm)
Pierce * 20 mm (3/4")
* Pierce rating for handheld use or with automatic torch height control.
Capacity Metal removal rate Groove profile
Gouging
Typical gouge 8,8 kg/hr
(19.5 lbs./hr)
5,8 mm D x 7,1 mm W
(0.23" D x 0.28" W)
Production cut chart
Material Thickness Current Production cut speed *
inches mm amps ipm mm/min
Mild steel 1/4 6 85 160 4400
1/2 12 85 56 1600
3/4 20 85 29 680
Stainless steel 1/4 6 85 164 4600
1/2 12 85 48 1400
3/4 20 85 24 570
Aluminum 1/4 6 85 172 4900
1/2 12 85 68 1930
3/4 20 85 37 880
*Production cut speeds are the result of Hypertherm's laboratory testing.
Production speeds are approximately 80% of maximum. For optimum cut quality, cutting speeds may vary based on different cutting applications. Refer to the operator manual for more details.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mechanized cutting
TorchOperating rangeShield / DeflectorRetaining cap / Retaining cap (ohmic)NozzleElectrodeSwirl ring
Duramax torches - Machine - 180° 25 A - 45 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220941 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Machine - 180° 45 A - 65 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220819 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Machine - 180° 65 A - 85 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220816 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Mini machine - 180° 25 A - 45 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220941 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Mini machine - 180° 45 A - 65 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220819 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Mini machine - 180° 65 A - 85 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220816 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 180° 25 A - 45 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220941 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 180° 45 A - 65 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220819 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 180° 65 A - 85 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220816 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 45° 25 A - 45 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220941 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 45° 45 A - 65 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220819 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 45° 65 A - 85 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220816 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 90° 25 A - 45 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220941 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 90° 45 A - 65 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220819 220842 / 220777 (CopperPlus long life upgrade) 220857
Duramax torches - Robotic - 90° 65 A - 85 A 220817 / 220955 (Unshielded deflector) 220854 / 220953 (Ohmic) 220816 220842 / 220777 (CopperPlus long life upgrade) 220857
Upgrades
Cartridge retrofit torches for Powermax45 XP/65/85/105/125
Cartridge retrofit torches can modernize your Powermax45® XP/65/85/105/125 systems by enabling use of Powermax® cartridge to simplify use and improve overall cutting performance.
Read more
Cartridge Adapters for Hypertherm Systems
The cartridge adapter lets you convert to Hypertherm’s cartridge consumable platform if you have a Powermax45® XP with a Duramax® Lock torch or a Powermax65®, Powermax85®, or Powermax105® with a Duramax torch, or Powermax125® with a Duramax Hyamp torch.
Read more
Powermax85 SYNC plasma cutter
Professional-grade 25 mm (1″) plasma cutter provides automated process set-up and a revolutionary cartridge consumable platform for ease of use and optimized performance. Featuring a wide variety of torches and application capabilities for handheld and mechanized cutting and gouging.
Read more
Accessories
Air filtration kits
Hypertherm air filtration kits protect Powermax® systems against contaminated air and moisture from air lines.
Read more
Automated communication kits
Upgrade kits for the Powermax65®/85 and Powermax65/85/105 SYNC™ systems for automated applications.
Read more
Leather torch sheaths
The Hypertherm leather torch sheath provides additional protection for torch leads against cuts, burn-through and abrasion.
Read more
Plasma angle cutting guides
Plasma angle cutting guide is designed for accurate hand cuts of angles and square edges.
Read more
Plasma circle cutting guide
Plasma circle cutting guides cut circles up to 28″ in diameter.
Read more
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Read more
System dust covers
Hypertherm system dust covers are made from a flame-retardant vinyl designed to protect your Powermax plasma cutting system from dust and dirt.
Read more
Wheel/gantry mount kits
Hypertherm wheel and gantry kits for added mobility to move Powermax plasma cutting systems.
Read more
Field service bulletins (42)
Showing 42 of 42 documents
Showing of 42 documents
Show all
Technical support
