| Part number | Voltage (VAC) |
| 078620 | 200 |
| 078621 | 208 |
| 078622 | 220 |
| 078623 | 240 |
| 078624 | 380 |
| 078625 | 400 |
| 078626 | 415 |
| 078627 | 440 |
| 078628 | 480 |
| 078629 | 600 |
XPR300 plasma cutting system
Interactive manuals now available
Find answers quickly to your installation, troubleshooting questions, and more. Select a manual.
How-to videos (7)
Showing 6 of 7 Videos
Operator and instruction manuals (10)
.XPR300 Plasma Instruction Manual (Revision 9) ADDENDUM
Showing 6 of 10 documents
Service manuals (2)
XPR Torch Rebuild and Filter Kit Maintenance Guide (Revision 2) (English)
XPR300 Torch Rebuild and Filter Kit Maintenance Guide (Revision 2) (Multilingual)
Showing 2 of 2 documents
Application notes (4)
CNC Communication Protocol for XPR cutting systems with the 141545 main control PCB (Revision 3)
Text Marking with ProNest and Phoenix Application Note (Revision 2)
Update XPR Firmware through Phoenix over EtherCAT (Revision 3)
Showing 4 of 4 documents
Specifications
| Maximum open-circuit voltage (U0) | 360 VDC |
| Maximum output current | 300 A |
| Maximum output power | 66.5 kW |
| Output voltage | 50 VDC–210 VDC |
| 100% duty arc voltage | 210 V |
| Duty cycle rating | 100% at 66.5 kW, 40° C (104° F) |
| Operational ambient temperature range | -10° C–40° C (14° F–104° F) |
| Power factor | 0.98 at 66.5 kW |
| Insulation | Class H |
| EMC emissions classification (CE models only) | Class A |
| Lift points | Top lift eye weight rating 680 kg (1,500 lb.) |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mild steel
| Amperage | Process | Shield cap | Shield | Nozzle retaining cap | Nozzle | Swirl ring | Electrode | Water tube |
| 50 A | O2/Air | 420200 | 420237 | 420365 | 420234 | 420233 | 420231 | 420368 |
| 80 A | O2/Air | 420200 | 420246 | 420365 | 420243 | 420242 | 420240 | 420368 |
| 130 A | O2/Air | 420200 | 420255 | 420365 | 420252 | 420242 | 420249 | 420368 |
| 170 A | O2/Air | 420200 | 420513 | 420365 | 420261 | 420260 | 420258 | 420368 |
| 220 A | O2/Air | 420200 | 420273 | 420365 | 420270 | 420406 | 420276 | 420368 |
| 300 A | O2/Air | 420200 | 420491 | 420365 | 420279 | 420406 | 420276 | 420368 |
Non-ferrous
| Air/Air | 420200 | 420291 | 420365 | 420288 | 420314 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420297 | 420323 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420306 | 420323 | 420294 | 420368 | |
| 130 A | N2/N2 | 420200 |
420318 |
420365 |
420315 |
420314 | 420356 | 420368 |
420356 |
420368 |
| Air/Air | 420200 | 420513 | 420365 | 420524 | 420260 | 420258 | 420368 | |
| H2-Ar-N2/N2 | 420200 | 420362 | 420365 | 420359 | 420358 | 420356 | 420368 | |
XPR Gouging Consumables
Mild Steel
Nozzle* | Swirl ring | Electrode | Water tube |
| 170A | O2/Air | 420200 | 10086659 | 420365 | 10087904 (.140) Bore |
420242 | 10086653 | 420368 |
| 300A | O2/Air | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A | O2/Air | 420200 | 10086659 | 420365 | 10086657 (.195) Bore |
*Reference "XPR Gouging Charts for Nozzle"
Stainless Steel
| 170A | H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
420242 | 10086650 | 420368 |
| N2/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
| 300A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087911 (.250) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
XPR300 starter kits
| Part number | Description |
| 428618 | XPR300 Mild steel consumables starter kit (torch included) |
| 428619 | XPR300 Stainless steel consumables starter kit (torch included) |
| 428616 | XPR300 Mild steel consumables starter kit |
| 428945 | XPR300 Core console non-ferrous consumables starter kit |
| 428617 | XPR300 Stainless steel consumables starter kit |
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Plasma power supply parts
Outer panel parts
| Part number | Description | Quantity | |
| 1 | 100872591 | Top panel with labels | 1 |
| 4287282 | |||
| 2 | 100872601 | Side panel with labels and handles | 2 |
| 4287272 | |||
| 3 | 100872561 | Front panel with "H" (not shown) and power-indicator Light Emitting Diode (LED) label | 1 |
| 4287252 | |||
| 4 | 100872581 | Rear panel with label and handles | 1 |
| 4287262 | |||
| 100866272 | Base (not shown) | 1 | |
1 Compatible only on systems with a serial number equal to or after XPR300-010000.
2 Compatible only on systems with a serial number before XPR300-010000.
Fans
| Part number | Description | Designator | Quantity | |
| 1 | 429002 | Power-indicator Light Emitting Diode (LED) | – | 1 |
| 2 | 229821 | Fan: 250 cfm, 48 VDC, 120 mm (4.72 inch) diameter | CTRLFAN 1, CTRLFAN 2 | 2 |
| 3 | 229822 | Fan: 890 cfm, 48 VDC, 254 mm (10 inch) diameter | HXFAN 1, HXFAN 2, MAGFAN 1, MAGFAN 2 | 4 |
| 4 | 003266 | Solid state relay | – | 1 |
| 5 | 141384 | Fan power distribution Printed Circuit Board (PCB) | PCB6 | 1 |
Heat exchanger
| 1 | 229717 | Heat-exchanger only | – | 1 |
Coolant system parts
| 1 | 127014 | Coolant reservoir cap | 1 |
| 2 | 229741 | Coolant flow meter | 1 |
| 3 | 229775 | Coolant level sensor | 1 |
| 4 | 101281 | Coolant filter bracket | 1 |
| 5 | 127344 | Coolant filter housing | 1 |
| 027005 | Coolant filter (fine) | 1 | |
| 6 | 229777 | Coolant hose (1 inch) | 1 |
| 7 | 428729 |
Coolant pump and motor assembly:
1 |
| 8 | 006132 | Coolant bypass check valve | 1 |
| 9 | 229721 | Coolant solenoid valve assembly | 1 |
| 10 | 229654 | Thermistor: Copper pipe clip with electrical connector | 1 |
| 11 | 127559 | Coolant pump screen (coarse) | 1 |
| 12 | 428973 | Kit: XPR® inlet pump fitting replacement, with O-ring on plug | 1 |
| 13 | 002561 | Coolant reservoir | 1 |
| 14 | 006113 | Coolant check valve | 1 |
| 428330 | Kit: Tubing (1 inch hose not included) | 1 |
Coolant adapters in the rear compartment
| 1 | 015889 | Elbow adapter: 1/2 inch NPT X 1/2 inch tube, 45° swivel | 2 |
| 2 | 015903 | Red ring: 1.13 inches inner diameter | 1 |
| 3 | 015888 | Adapter: 1/2 inch FNPT X 1-1/2 inch length bulkhead | 2 |
| 015899 | Red ring: 0.87 inch inner diameter (not shown) | 1 | |
| 4 | 015029 | Adapter: 1/2 inch NPT X #8 male | 2 |
| 015898 | Green ring: 0.87 inch inner diameter (not shown) | 1 | |
| 5 | 015902 | Green ring: 1.13 inch inner diameter | 1 |
Other adapters not shown
| Part number | Description | Location | Quantity |
| 015669 | Male adapter: 3/8 inch NPT X 1/2 inch tube | in coolant solenoid valve | 1 |
| 006099 | Coolant drain valve: 1/4 inch NPT X 3/8 inch tube | in the bottom of the coolant reservoir | 1 |
| 015073 | Adapter: 1/4 inch NPT X 1/4 FPT | in the bottom of the coolant reservoir | 1 |
| 015738 | Elbow adapter: 1/4 inch NPT X 1/2 inch tube, 45° swivel | in the top of the coolant reservoir | 1 |
| 015510 | Adapter: 1/4 inch X hexagonal collar | between the flow meter and coolant reservoir | 1 |
| 015663 | Adapter: 1/4 inch NPT X 1/2 inch tube | in the flow meter and coolant bypass check valve | 2 |
| 015668 | Elbow adapter: 1/2 inch NPT X 1/2 inch tube, 90° | in the coolant filter (fine) assembly | 2 |
| 104807 | Nut for chopper fitting | on the back of the chopper | 4 |
| 015815 | Elbow fitting: 1/2 inch tube X 1/2 inch tube, 90° | on the back of the chopper and the heat-exchanger inlet | 5 |
| 015820 | Fitting: 1/2 inch tube X 1/2 inch tube | heat-exchanger outlet | 1 |
Transformers and inductors
| 1 | – | Transformer, horizontal, 66.5 kW, 3-phase 1 | T2 | 1 |
| 2 | 428844 | Kit: Inductor 1A (top)/1B (bottom) | L1 | 1 |
| 3 | 428845 | Kit: Inductor 2A (top)/2B (bottom) | L2 | 1 |
1 You cannot purchase this part. Shown for reference only.
Control side – view 1
| 1 | 003266 | Solid state relay | – | 1 |
| 2 | 229671 | Power source: 88 VAC - 264 VAC to 48 VDC, 600 W | PS2 | 1 |
| 3 | 428893 | Power distribution Printed Circuit Board (PCB) | PCB7 | 1 |
| 10084820 | Fuse: 15 A, 250 VAC, time delay (on PCB7) | F1, F2 | 2 | |
| 108709 | Fuse: 10 A, 250 VAC, time delay (on PCB7) | F3 | 1 | |
| 4 | Control transformer assembly, 3 kVA | |||
| 229809 | 200 V, 50 Hz – 60 Hz | T1 | 1 | |
| 229810 | 208 V, 60 Hz | |||
| 229811 | 220 V, 50 Hz – 60 Hz | |||
| 229812 | 240 V, 60 Hz | |||
| 229813 | 380 V, 50 Hz | |||
| 229814 | 400 V, 50 Hz | |||
| 229815 | 415 V, 50 Hz | |||
| 229816 | 440 V, 50 Hz – 60 Hz | |||
| 229794 | 480 V, 60 Hz | |||
| 229817 | 600 V, 60 Hz | |||
| 5 | 229678 | Start circuit assembly | PCB4 | 1 |
Control side – view 2
| 1 | 229640 | Power source: 88 VAC – 264 VAC to 24 VDC | PS1 | 1 |
| 2 | 10084334 | Kit: XPR® main control Printed Circuit Board (PCB) assembly and wireless tag | PCB1 | 1 |
| 10088158 | Kit: Wireless (Wi-Fi®) module for main control PCB and wireless tag (not shown) | U83 | 1 | |
| 3 | 141597 | Plasma power supply expansion PCB | PCB9 | 1 |
| 4 | 208394 | Fuse holder: 2P, 30 A, 600 V | – | 1 |
| 208395 | Fuse: 8 A, 600 V, Class R (used in 380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | F1, F2 | 2 | |
| 208397 | Fuse: 15 A, 600 V, Class R (used in 200 V, 208 V, 220 V, 240 V) | |||
| 5 | 10081573 | Input/Output (I/O) PCB | PCB5 | 1 |
| 6 | 003277 | Pilot arc relay: 24 VDC, coil, 60 A 28 VDC contacts | CR1 | 1 |
| 7 | 101316 | Pilot arc relay cover | – | 1 |
| 8 | 10085251 | Chopper assembly | Chopper 1, Chopper 2 | 2 |
Wire harnesses and CAN cables in plasma power supply
| 528134 | Wire harnesses for the XPR300®:
| 10081204 | Wire harness for the fan power distribution Printed Circuit Board (PCB) |
| 223399 |
Controller Area Network (CAN) cable 0.5 m (1.6 ft) Located between the control PCB and chopper. |
| 223400 |
CAN cable 1 m (3.3 ft) Located between the choppers. |
Rear compartment of the plasma power supply
| A | 200 V, 208 V, 240 V plasma power supplies |
| B | 380 V, 400 V, 415 V, 440 V, 480 V, 600 V plasma power supplies |
| 1 | 229697 | Inrush contactor: 80 A, IEC AC-3, 3-phase, 120 VAC | IR_CON | 1 |
| 2 | 209274 | Inrush resistor assembly, 2 Ω X 3 | – | 1 |
| 3 | 229033 | Terminal block 600 V, 200 A (380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | TB1 | 1 |
| 4 | 029316 | Terminal block 600 V, 140 A (380 V, 440 V, 480 V, 600 V) | ||
| 5 | 003276 | Main contactor (200 V, 208 V, 220 V, 240 V) | M_CON | 1 |
| 429060 | Main contactor assembly (380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | |||
| 6 | 141511 | VDC3 Printed Circuit Board (PCB) (Optional, for use with RS-422 and discrete cutting systems) | – | 1 |
| 10080016 | Kit: Replacement output terminals for connecting work cables and pilot arc cables in the plasma power supply | – | – |
Preventive maintenance
XPR torch and filter maintenance kit (with coolant)
XPR® torch and filter maintenance kit (with coolant) includes all necessary parts for your XPR system.
XPR torch and filter maintenance kit (without coolant)
XPR torch and filter maintenance kit (without coolant) includes all necessary parts for your XPR system.
XPR300 preventive maintenance kit (200V – 240V)
Preventive maintenance kits include all necessary parts for your XPR300® plasma system (200V – 240V).
XPR300 preventive maintenance kit (380V – 600V)
Preventive maintenance kits include all necessary parts for your XPR300™ plasma system (380V – 600V).
.XPR Preventive Maintenance Program Instruction Manual (Revision 3)
Field service bulletins (17)
Multi-Ratio Voltage Divider PCB (0 V - 10 V) Installation Steps for XPR, MAXPRO200, and HPRXD (Revision 0)
Phoenix Passwords Field Service Bulletin for End Users (Revision 4)
XPR Control PCB Replacement Steps Field Service Bulletin (Revision 1)
Showing 6 of 17 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
