| Part number | Voltage (VAC) |
| 078650 | 200 |
| 078651 | 208 |
| 078652 | 220 |
| 078653 | 240 |
| 078654 | 380 |
| 078655 | 400 |
| 078656 | 415 |
| 078657 | 440 |
| 078658 | 480 |
| 078659 | 600 |
XPR460 plasma cutting system
Interactive manuals now available
Find answers quickly to your installation, troubleshooting questions, and more. Select a manual.
How-to videos (1)
Showing 1 of 1 Videos
Operator and instruction manuals (7)
.XPR460 Plasma Instruction Manual (Revision 0) ADDENDUM
Showing 6 of 7 documents
Application notes (2)
CNC Communication Protocol for XPR cutting systems with the 141545 main control PCB (Revision 3)
XPR™ True Hole Conversion on an EDGE Connect CNC (Revision 1)
Showing 2 of 2 documents
Specifications
| Maximum open-circuit voltage | 360 VDC |
| Maximum output current | 460 A |
| Maximum output power | 102 kW |
| Output voltage | 50–222 VDC |
| 100% duty arc voltage | 222 V |
| Duty cycle rating | 100% at 102 kW, 40° C (104° F) |
| Operational ambient temperature range | -10° C–40° C (14° F–104° F) |
| Power factor | 0.98 at 102 kW |
| Insulation | Class H |
| EMC emissions classification (CE models only) | Class A |
| IP rating | IP21 |
| Unit dimensions |
H = 124.8 cm (49.12″) L = 123.8 cm (48.75″) W = 90.5 cm (35.64″) |
| Lift points |
Top lift eye weight rating 680 kg (1,500 lb.) Bottom life truck slots |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mild steel
| Amperage | Process | Shield cap | Shield | Nozzle retaining cap | Nozzle | Swirl ring | Electrode | Water tube |
| 50 A | O2/Air | 420200 | 420237 | 420365 | 420234 | 420233 | 420231 | 420368 |
| 80 A | O2/Air | 420200 | 420246 | 420365 | 420243 | 420242 | 420240 | 420368 |
| 130 A | O2/Air | 420200 | 420255 | 420365 | 420252 | 420242 | 420249 | 420368 |
| 170 A | O2/Air | 420200 | 420513 | 420365 | 420261 | 420260 | 420258 | 420368 |
| 220 A | O2/Air | 420200 | 420273 | 420365 | 420270 | 420406 | 420276 | 420368 |
| 300 A | O2/Air | 420200 | 420491 | 420365 | 420279 | 420406 | 420276 | 420368 |
| 460 A | O2/Air | 420200 | 520002 | 420365 | 520001 | 420819 | 420834 | 420368 |
Non-ferrous
| Air/Air | 420200 | 420291 | 420365 | 420288 | 420314 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420297 | 420323 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420306 | 420323 | 420294 | 420368 | |
| 130 A | N2/N2 | 420200 |
420318 |
420365 |
420315 |
420314 | 420356 | 420368 |
420356 |
420368 |
| Air/Air | 420200 | 420513 | 420365 | 420524 | 420260 | 420258 | 420368 | |
| H2-Ar-N2/N2 | 420200 | 420362 | 420365 | 420359 | 420358 | 420356 | 420368 | |
| N2/H2O | 420200 | 420475 | 420365 | 420359 | 420323 | 420356 | 420368 | |
| 460 A | H2-Ar-N2/N2 | 420200 | 420998 | 420365 | 420996 | 420358 | 420997 | 420368 |
XPR Gouging Consumables
Mild Steel
Nozzle* | Swirl ring | Electrode | Water tube |
| 170A | O2/Air | 420200 | 10086659 | 420365 | 10087904 (.140) Bore |
420242 | 10086653 | 420368 |
| 300A | O2/Air | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A | O2/Air | 420200 | 10086659 | 420365 | 10086657 (.195) Bore |
*Reference "XPR Gouging Charts for Nozzle"
Stainless Steel
| 170A | H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
420242 | 10086650 | 420368 |
| N2/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
| 300A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087911 (.250) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
XPR460 starter kits
| Part number | Description |
| 10083904 | XPR460 Mild steel consumables starter kit |
| 10083905 | XPR460 Mild steel consumables starter kit (torch included) |
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Plasma power supply parts
Outer panel parts
| Part number | Description | Quantity | |
| 1 | 10084227 | Top panel with labels | 1 |
| 2 | 10084228 | Side panel with labels and handles | 2 |
| 3 | 10084230 | Front panel with "H" (not shown) and power-indicator Light Emitting Diode (LED) label | 1 |
| 4 | 10084229 | Rear panel with label and handles | 1 |
Fans
| Part number | Description | Designator | Quantity |
| 429002 | Power-indicator Light Emitting Diode (LED) | - | 1 |
| 229821 | Fan: 250 cfm, 48 VDC, 120 mm (4.72 inch) diameter | CAB FAN 1 | 1 |
| 229822 | Fan: 890 cfm, 48 VDC, 254 mm (10 inch) diameter | MAGFAN 1, MAGFAN 2, MAGFAN 3 | 3 |
| 003266 | Solid state relay | - | 1 |
| 141384 | Fan power distribution Printed Circuit Board (PCB) | PCB6 | 1 |
Coolant adapters and manifold in the rear compartment
| 10082412 | Coolant manifold assembly | 1 | |
| 1 | 204405 | Coolant connections manifold | 1 |
| 2 | 015938 | Elbow adapter: 3/8 inch NPT X 1/2 inch tube, 45° swivel | 2 |
| 3 | 10082222 | Adapter: 3/8 inch NPT X #6 male BRS | 2 |
| 4 | 10083877 | Green ring: 0.70 inch inner diameter | 1 |
| 5 | 10083878 | Red ring: 0.70 inch inner diameter | 1 |
Coolant adapters and manifolds in plasma power supply
| Part number | Description | Location | Quantity |
| 10082411 | Chopper manifold assembly | on the back of the choppers | 1 |
| 015663 | Adapter: 1/4 inch NPT X 1/2 inch tube | on the manifold behind choppers | 6 |
| 015664 | Elbow adapter: 1/4 inch NPT X 1/2 inch tube | on the manifold behind choppers | 2 |
| 015729 | Green ring: 0.50 inch inner diameter | on the manifold behind choppers | 1 |
| 015730 | Red ring: 0.50 inch inner diameter | on the manifold behind choppers | 1 |
| 104807 | Nut for chopper fitting | on the back of the choppers | 6 |
| 015815 | Elbow fitting: 1/2 inch tube X 1/2 inch tube, 90° | on the back of the choppers | 6 |
| 528123 | Kit: Tubing for plasma power supply | - | 1 |
Transformers and inductors
| Part number | Description | Designator | Quantity | |
| 1 | - | Transformer, horizontal, 102.12 kW, 3-phase 1 | T2 | 1 |
| 2 | 10084075 | Kit: Inductor 1A (top)/1B (bottom) | L1 | 1 |
| 3 | 10084076 | Kit: Inductor 2A (top)/2B (bottom) | L2 | 1 |
| 4 | 10084077 | Kit: Inductor 3A (top)/3B (bottom) | L3 | 1 |
| 10084200 | Kit: Thermistor for the main transformer | - | 2 | |
1 You cannot purchase this part. Shown for reference only.
Control parts - 1
| 229640 | Power source: 88 VAC - 264 VAC to 24 VDC | PS1 | 1 |
| 10084334 | Control Printed Circuit Board (PCB) with wireless tag | PCB1 | 1 |
| 141592 | Wireless module for control PCB | U83 | 1 |
| 141597 | Plasma power supply expansion PCB | PCB9 | 1 |
| 208394 | Fuse holder: 2P, 30 A, 600 V | - | 1 |
| 208395 | Fuse: 8 A, 600 V, Class R (used in 380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | F1, F2 | 2 |
| 208397 | Fuse: 15 A, 600 V, Class R (used in 200 V, 208 V, 220 V, 240 V) | ||
| 10085206 | Input/Output (I/O) PCB | PCB5 | 1 |
| 003277 | Pilot arc relay: 24 VDC, coil, 60 A 28 VDC contacts | CR1 | 1 |
| 003277 | Cooler power relay: 24 VDC, coil, 60 A 28 VDC contacts | - | 1 |
| 101316 | Relay cover (pilot arc relay and cooler power relay) | - | 2 |
| 10085251 | Chopper assembly | Chopper 1, Chopper 2, Chopper 3 | 3 |
Control parts - 2
Wire harness and CAN cables in the plasma power supply
| 429117 | XPR460 wire harness |
| 223399 | Controller Area Network (CAN) cable 0.5 m (1.6 ft) (Located between the choppers.) |
| 223400 | CAN cable 1 m (3.3 ft) (Located between the control Printed Circuit Board (PCB) and chopper.) |
Rear compartment of the plasma power supply
| 003297 | Inrush contactor: 80 A, IEC AC-3, 3-phase, 120 VAC | IR_CON | 1 |
| 209274 | Inrush resistor assembly, 2 Ω X 3 | - | 1 |
| 229033 | Terminal block 600 V, 200 A (380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | TB1 | 1 |
| 10084059 | Terminal block 600 V, 410 A (200 V, 208 V, 220 V, 240 V) | ||
| 10084340 | Main contactor (200 V, 208 V, 220 V, 240 V) | M_CON | 1 |
| 10084339 | Main contactor assembly (380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | ||
| 10083630 | Strain relief (380 V, 400 V, 415 V, 440 V, 480 V, 600 V) | - | 1 |
Preventive maintenance
.XPR Preventive Maintenance Program Instruction Manual (Revision 3)
Field service bulletins (5)
XPR Control PCB Replacement Steps Field Service Bulletin (Revision 1)
XPR Gas Connect Console Ignition Coil Replacement Information (Revision 0)
Showing 5 of 5 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
