Specifications
The HPR800XD system is comprised of two HPR400XD systems in parallel. Each power supply has the following specifications.
General
Maximum OCV (U0) 360 VDC
Maximum output current (I2) 400 Amps
Output voltage (U2) 50 – 200 VDC
Duty cycle rating (X) 100% @ 80 kw, 40° C (104° F)
Ambient temperature/Duty cycle Power supplies will operate between -10° C and +40° C (+14° and 104° F)
Power factor (cosφ) 0.98 @ 400 ADC output
Cooling Forced air (Class F)
Insulation Class H
Mild steel cut capacity Dross free
Production pierce
Maximum cutting capacity
38 mm (1-1/2")
50 mm (2")
80 mm (3.2")
Stainless steel cut capacity Production pierce
Maximum pierce**
Severance
75 mm (3")
100 mm (4")
160 mm (6-1/4")
Aluminum cut capacity Production pierce
Severance
75 mm (3")
160 mm (6-1/4")
Speed
(Mild steel)
Book specification at highest output current
12 mm (1/2")
4430 mm/m
(170 ipm)
Cut angle ISO 9013 range*
2-5
Weldability   Ready to weld
Process gases
by material
(Plasma/shield)
Mild steel
Stainless steel
Aluminum
02/Air, 02/02
Ar/Air
H35/N2, N2/N2, H35-N2/N2, F5/N2
Ar/Air, Ar//N2
H35/N2, Air/Air, H35-N2/N2
Ar/Air, Ar//N2
Process amps
(Cutting)
Not all processes available
for all materials
30-800
** Maximum pierce requires use of an autogas console and controlled motion process. See technical documentation for details.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
HPR cartridge
HPR cartridge consumablesNew!
Mild steel process Retaining cap Cartridge (10 pk) Water tube Torch body
80 A (standard cutting / bevel cutting)* 420708 420803 420728 420729
130 A (standard cutting / bevel cutting)* 420708 420705 420728 420729
260 A (standard cutting / bevel cutting)* 420708 420715 420728 420729
400 A (standard cutting / bevel cutting)* 420708 420727 420728 420729
HPR cartridge kitsNew!
Type Kit p/n Includes p/n Description Quantity
Torch starter kit 528101 420729  Torch body 1
    420728 Water tube 1
    420708 Retaining cap 1
    528107 Kit: O-ring cartridge torch 1
Cartridge 3-pk kits
528102 420803 Kit: Cartridge, 80 A 3
  528103
420705
Kit: Cartridge, 130 A 3
  528104 420715 Kit: Cartridge, 260 A 3
   528105 420803, 420705, 420715 Kit: Cartridge, multi-amps kit contains (1) of each amperage (80 A, 130 A, and 260 A) 3
  528165 420727 Kit: Cartridge, 400 A 3
  528166 420705, 420715, 420727 Kit: HPRXD Cartridge, high-amps kit contains (1) of each amperage (130 A, 260 A, and 400 A) 3
HPR800XD standard consumables
HPR800XD torch
HPRXD torch
Mild steel
Shield cap     Shield   Nozzle retaining cap       NozzleSwirl Ring Electrode Water tube  30 amp Torch consumable parts
400 amp consumables - mild steel
Amperage Shield
cap
Shield Nozzle
retaining cap
Nozzle Swirl ring Electrode SilverPlus
electrode
Water tube
30 A 220747 220194 220754 220193 220180 220192 ______ 220340
50 A 220747 220555 220754 220554 220553 220552 ______ 220340
80 A 220747 220189 220756 220188 220179 220187 420566 220340
130 A 220747 220183 220756 220182 220179 220181 220665 220340
200 A 220637 220761 220757 220354 220353 220352 220666 220340
260 A 220637 220764 220760 220439 220436 220435 220668 220340
400 A 220637 220636 220635 220632 220631 220629 420530 220571
80 A bevel 220637 220742 220845 220806 220179 220802 ______ 220700
130 A bevel 220637 220742 220740 220646 220179 220649 ______ 220700
200 A bevel 220637 220658 220845 220659 220353 220662 ______ 220700
260 A bevel 220637 220741 220740 220542 220436 220541 ______ 220571
* 260 A bevel 220637 220897 220896 220898 220436 220899 ______ 220571
400 A bevel 220637 220636 220635 220632 220631 220629 ______ 220571
* Recommended for use if you have excessive slag, or the torch is misfiring, when using standard consumables.
Stainless steel
Shield capShieldNozzle retaining cap Nozzle Swirl Ring Electrode Water tube  800 amp Torch consumable parts
800 amp - stainless steel - above 4" thick
Amperage Shield
cap
Shield Nozzle
retaining cap
Nozzle Swirl ring Electrode Water tube
45 A 220747 220202 220755 220201 220180 220308 220340
60 A HDi 220747 220815 220814 220847 220180 220339 220340
80 A 220747 220338 220755 220337 220179 220339 220340
130 A 220747 220198 220755 (H35) 220197 220179 220307 220340
      220756 (N2)
200 A 220637 220762 220758 220343 220342 220307 220340
260 A 220637 220763 220758 220406 220405 220307 220340
400 A 220637 220707 220712 220708 220405 220709 220571
600 A 220637 220707 220635 (H35) 220859 220353 (H35) 220709 220571
      220885 (N2)   220405 (N2)
800 A
4" (100 mm) and below
220637 220886 220885 220884 220353 220882 220881
800 A
above 4" (100 mm)
220637 220886 220712 220884 220350 220882 220881
130 A bevel 220637 220738 220739 220656 220179 220606 220571
260 A bevel 220637 220738 220739 220607 220405 220606 220571
400 A bevel 220637 220707 220712 220708 220405 220709 220571
600 A bevel 220637 220707 220635 (H35) 220859 220353 (H35) 220709 220571
800 A bevel
800 A bevel
above 4" (100 mm)
Aluminum
800 amp - aluminum consumables - above 4" thick
Amperage Shield
cap
Shield Nozzle
retaining cap
45 A 220747 220202 220756 220201 220180 220308 220340
130 A 220747 220198 220755 (H35) 220197 220179 220307 (H35) 220340
      220756 (Air)     220181 (Air)
200 A 220637 220762 220759 220346 220342 220307 220340
600 A 220637 220707 220712 (H35) 220859 220353 (H35) 220709 220571
800 A
800 A
above 4" (100 mm)
HPR800XD standard consumable starter kits
Designed especially for your HPR800XD system, the Hypertherm consumable kit contains all the necessary consumables and accessories you need to get up-and-cutting. Customers can choose either mild or stainless steel/aluminum consumable starter kits.
Kit type (MS) HPR400XD mild steel starter kit
(400 A and below)
Kit part number 228367
Description Kit contains all the necessary consumables and accessories for mild steel cutting at 400 A and below
Kit type (AL/SS) HPR400XD aluminum and stainless steel starter kit
(400 A and below)
Kit part number 228368
Description Kit contains all the necessary consumables and accessories for aluminum and stainless steel cutting at 400 A and below
Kit type (AL/SS) HPR800XD aluminum and stainless steel starter kit
(600 A/800 A)
Kit part number 228603
Description Kit contains all the necessary consumables and accessories for aluminum and stainless steel cutting at 600 A/800 A
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Power supplies
Primary
Primary
with
Hypernet
Secondary
Voltage
(AC)
078578
078586
078594
200/208
078579
078587
078595
220
078580
078588
078596
240
078581
078589
078597
380
078582
078590
078598
400
078583
078591
078599
440
078584
078592
078600
480
078585
078593
078601
600
Power supply - Exterior, front and sides
HPR400XD aut gas power supply exterior, front and sides
Item Part Number Description Qty.
1 See table above Power supply
2 228609 Panel: Left side, with labels and handles (not shown) 1
3 3228362 Panel: Top, with labels 1
4 075241 Sheet metal screws 1
5 228610 Panel: Right side, with labels and handles 1
6 228619 Panel: Front, with labels (Primary power supply) 1
  228620 Panel: Front, with labels (Secondary power supply) 1
7 129633 Green power lamp assembly 1
8 228604 Kit: Hypernet upgrade (not shown) 1
Power supply - Exterior, rear
HPR400XD power supply - auto gas - exterior, rear
Item Part Number Description Designator Qty.
1 229214* Terminal block: Input power TB1 1
  229033** Terminal block: Input power TB1 1
2 229195 EMI filter (400 volt power supply only)   1
3 428064*** Kit: HPR400XD/800XD inrush-suppression circuit   1
4a 129792 Chopper assembly CHA 1
4b 129792 Chopper assembly CHB 1
4c 129792 Chopper assembly CHC 1
4d 129792 Chopper assembly CHD 1
  127039 6 in. fan: 230 CFM, 115 VAC 50-60 HZ   8
5a 014080 Inductor: 100 amp, 4 mH L1 1
5b 014080 Inductor: 100 amp, 4 mH L2 1
5c 014080 Inductor: 100 amp, 4 mH L3 1
5d 014080 Inductor: 100 amp, 4 mH L4 1
6 003218* Main contactor CON1 1
  003233** Main contactor CON1 1
7 428382† Kit: HPR400XD/800XD inrush PCB   1
8 003249 Inrush contactor   1
* 200, 220, and 240 volt power supplies
** 380, 400, 440, 480, and 600 volt power supplies
*** If your power supply does not have the inrush-suppression circuit, you can install kit 428064 to add it.
† If your power supply has an inrush-suppression circuit, you can install kit 428382 to upgrade it to an inrush PCB.
Power supply - interior, electrical
Power supply interior electrical
1 108847* Fuse: 7.5 amp, 600 volt, high surge F1, F2 2
  008709** Fuse: 20 amp, 500 volt, slow blow F1, F2 2
2 229340 Snubber assembly   1
3 229360 Contactor: 500 amp DC 120 VAC COIL Con2, Con3 2
4 104496 Bus bar   1
5 104495 Bus bar   1
6 229213 PCB: I/O   1
7 003149*** Relay: Pilot arc, 120 VAC CR1 1
8 229238 Start circuit assembly PCB1 1
9a 109004 Current sensor: Hall 100 amp, 4 volt CS1 1
9b 109004 Current sensor: Hall 100 amp, 4 volt CS2 1
9c 109004 Current sensor: Hall 100 amp, 4 volt CS3 1
9d 109004 Current sensor: Hall 100 amp, 4 volt CS4 1
10 014321 200 volt main transformer: 80KW, 3 ph, 50 HZ T2 1
  014322 220 volt main transformer: 80KW, 3 ph, 50 HZ   1
  014323 240 volt main transformer: 80KW, 3 ph, 60 HZ   1
  014324 380 volt main transformer: 80KW, 3 ph, 50 HZ   1
  014325 400 volt main transformer: 80KW, 3 ph, 50 HZ   1
  014326 440 volt main transformer: 80KW, 3 ph, 50 HZ   1
  014327 480 volt main transformer: 80KW, 3 ph, 60 HZ   1
  014328 600 volt main transformer: 80KW, 3 ph, 60 HZ   1
  228309 Kit: Thermistor replacement for main transformer   1
** 200, 220, and 240 volt power supplies
*** CR1 is located under the cover
Power supply - Interior, PCB parts
HPR400XD auto gas interior PCB parts
1 141027 PCB: Pump motor drive PCB7 1
2 229212 Inductor: 5 amp, 1.4 mH   2
3 041802 Non-Eco Design PCB: Power distribution PCB2 1
    A power supply with serial number HPR800P-000297 or HPR800S-000295 or earlier has this PCB
  108028   Fuse: 3 amp, 250 volt F5, F6, F7 3
  108075   Fuse: 6.3 amp, 250 volt (slow-blow) F1, F2, F3 3
  108709   Fuse: 10 amp, 250 volt F4 1
  229339   Non-Eco design wire harness   1
3 10078615 MOST RECENT PCB: Power distribution PCB2 1
    A power supply with serial number HPR800P-010001 or HPR800S-010001 or later has this PCB
  10081508   Eco Wire harness – Necessary with the 10078615 power distribution PCB*   1
4 141030 PCB (Primary power supply): Control PCB3 1
4 141144 PCB (Secondary power supply): Control PCB3 1
5 027079 10 in. fan: 450-550 CFM, 120 VAC 50-60 HZ   3
6 229225 Control transformer: 400 volt, 50-60 HZ T2 1
  229226 Control transformer: 380 volt, 50-60 HZ   1
  229227 Control transformer: 480 volt, 60 HZ   1
  229228 Control transformer: 600 volt, 60 HZ   1
  229230 Control transformer: 240 volt, 60 HZ   1
  229231 Control transformer: 200 and 208 volt, 50-60 HZ   1
  229232 Control transformer: 440 volt, 50-60 HZ   1
  229233 Control transformer: 220 volt, 50-60 HZ   1
* You need the 10081508 wire harness to make connections between the 10078615 power distribution PCB and the 141030 control PCB. The 229339 wire harness is not compatible with the 10078615 power distribution PCB.
Preventive maintenance
Upgrades
SilverPlus electrodes
SilverPlus® electrodes last over two times longer than standard copper electrodes  significantly lower operating costs and reducing the number of changeouts.
Read more
XPR300 plasma cutting system
Cut faster and use fewer consumables with the XPR300® mechanized plasma cutting system. With unmatched X-Definition® cut quality on mild steel, stainless steel and aluminum, the XPR300 increases cut speed, dramatically improves productivity and slashes operating costs.
Read more
XPR460 plasma cutting system
Part of the Hypertherm XPR® family, the XPR460 delivers the most consistent cut quality, thicker cutting capability, and faster cutting speeds in its class—increasing productivity and lowering operating costs.
Read more
Field service bulletins (9)
Showing 9 of 9 documents
Showing of 9 documents
Show all
Technical support
