Operator and instruction manuals (6)
HySpeed HSD130 130 A SilverPlus Cut Chart Update
HySpeed HSD130 Local High Frequency (LHF) Instruction Manual
Showing 6 of 6 documents
Specifications
| Capacity | ||
| Mild Steel | Dross free Production (pierce) Severance (edge starts) |
16 mm (5/8") 25 mm (1") 38 mm (1-1⁄2") |
| Stainless Steel | Production (pierce) Severance (edge starts) |
20 mm (3/4") 25 mm (1") |
| Aluminum | Production (pierce) Severance (edge starts) |
| Speed* (Mild steel) |
Book specification at highest output current | 12 mm (1/2") 2200 mm/m (80 ipm) |
| Cut angle | ISO 9013 range** | 4 |
| Weldability | Ready to weld | |
| Process gases by material (Plasma/shield) |
Mild steel Stainless steel Aluminum |
02/Air, Air/Air Air/Air, N2/N2, F5/N2, H35/N2 Air/Air, H35/N2 |
| Process amps (Cutting) |
Not all processes available for all materials |
45-130 |
* Note: Take care in comparison: competitors often show maximum cutting speeds rather than speeds that deliver the best cuts, as shown above. Cut speeds listed above deliver best cut quality, but cut speeds can be up to 50% faster.
** ISO 9013 is a standard that defines cut quality of thermally cut parts. The lower the range (range 1 is the lowest), the smaller the angle on the cut face. Cut angle in range 4 is better than in range 5.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
HSD130 consumables
HSD130 starter kits
| Kit type | HSD130 mild steel starter kit (130 A and below) |
| Kit part number | 228146 |
| Description | Kit contains all the necessary consumables and accessories for mild steel cutting at 130 A and below |
| Kit type | HSD130 aluminum and stainless steel starter kit (130 A and below) |
| Kit part number | 228156 |
| Description | Kit contains all the necessary consumables and accessories for aluminum and stainless steel cutting at 130 A and below |
Preventive maintenance
HSD130 preventive maintenance kits
Designed especially for your HySpeed® HSD130™ plasma system, the Hypertherm preventive maintenance kit contains all the necessary parts you need to keep your system operating at peak performance.
Upgrades
MAXPRO200 plasma cutter
Dubbed the industry workhorse because of its power and 100% duty cycle, the MAXPRO200® plasma cutter is designed for your heavy-duty, high-capacity automated and handheld cutting and gouging applications. MAXPRO200. Get work done.
Field service bulletins (7)
Showing 6 of 7 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
