Interactive manuals now available
Find answers quickly to your installation, troubleshooting questions, and more. Select a manual.
Operator and instruction manuals (15)
Showing 15 of 15 documents
Showing of 15 documents
Show all
Service manuals (3)
Showing 3 of 3 documents
Showing of 3 documents
Specifications
Cut and gouge capacities
Cut capacity Thickness Cut speed
Recommended 32 mm (1-1/4″) 500 mm/min (20 ipm)
  38 mm (1-1/2″) 250 mm/min (10 ipm)
Severance (hand cutting) 50 mm (2″) 125 mm/min (5 ipm)
Pierce* 22 mm (7/8″)
*Pierce rating for handheld use or with automatic torch height control
Gouge capacity Metal removal rate Groove profile
Typical gouge 8,6 kg (19.1 lbs.) per hour 6,6 mm D x 6,0 mm W (0.26″ D x 0.24″ W)
General specifications
Specifications - CSA
Input voltages (± 10%)
200–600 V, 3-PH, 50/60 Hz
Input current @ 16.8 kW
200/208/240/480/600 V, 3-PH 58/56/49/25/22 A
Output current
30–105 A
Rated output voltage
160 VDC
Duty cycle @ 40° C (104° F)
70% @ 105 A, 240 V, 3-PH
80% @ 105 A, 480–600 V, 3-PH
100% @ 94 A, 480–600 V, 3-PH
100% @ 88 A, 240 V, 3-PH
Open circuit voltage (OCV)
300 VDC
Weight with 7,6 m (25′) torch
230-400 V: 42.7 kg (94 lbs.)
CSA – for use in the Americas and Asia, except China
Specifications - CE/CCC
200-600 V, 3-PH, 50/60 Hz
380-400 V, 3-PH, 50/60 Hz
Output current
30–105 A
160 VDC
80% @ 105 A, 400 V, 3-PH
100% @ 94 A, 400 V, 3-PH
100% @ 88 A, 230 V, 3-PH
288 VDC
39.4 kg (87 lbs.)
CE – for use in Europe, Australia & New Zealand - RCM, Serbia, UK – UKCA, Ukraine, and other countries where accepted. CCC – for use in China.
Dimensions with handles
592 mm D; 274 mm W; 508 mm H (23.3″ D; 10.8″ W; 20.0″ H)
Gas supply
Clean, dry, oil-free air or nitrogen
Recommended inlet gas flow rate
Cutting: 260 I/min @ 6.2 bar (550 scfh, 9.1 scfm @ 90 psi)
Gouging: 260 I/min @ 4.8 bar (550 scfh, 9.1 scfm @ 70 psi)
Input power cable length
3 m (10′)
Power supply type
Inverter–IGBT
Engine drive requirement
30 kW or 37.5 kVA for full 105 A output
Electrical efficiency
91%
Recyclability
100%
Warranty
Power supply: 6-year, Torch: 1-year
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
CARTRIDGE-105-Drag-Fine-Hand
Drag cutting and FineCut for hand torches
Hypertherm cartridges
Process
Cartridge
Hyamp
528162
105 A
428937
85 A
428935
65 A
428931
45 A
30-45 A FineCut® hand cutting
Drag cartridge:
FineCut cartridge:
CARTRIDGE-105-Mech-standoff-Fine
Process
Cartridge
Hyamp
528161
105 A
428936
85 A
428934
65 A
428930
45 A
FineCut® mechanized cutting
Ohmic ring kit
428895
CARTRIDGE-105-MaxControlRemoval-Mech
Process
Cartridge
Max removal gouging 105 A
428938
Max removal gouging 45–85 A
428932
Max control gouging 105 A
428939
Max control gouging 45–85 A
428933
CARTRIDGE-105-FlushCut
FlushCut
Process
FlushCut™
105 A
428954
85 A
428953
65 A
428952
CARTRIDGE-65-HyAccess
HyAccess cartridges
Process
HyAccess™
Drag cutting 65 A
428984
Gouging 65 A
428987
Mechanized cutting 65 A
528079
CARTRIDGE-105-HYPILOT-mechanized
Process
HyPilot
Mechanized cutting 105 A
528157
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Plasma power supply exterior, front
Exterior, front for Powermax SYNC
Item
Part number
Description
1
528009
Kit: Powermax65 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528010
Kit: Powermax65 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
1
528011
Kit: Powermax85 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528012
Kit: Powermax85 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
1
528013
Kit: Powermax105 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528014
Kit: Powermax105 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
2
428143
Kit: Adjustment knob only
3
428141
Kit: Replacement screws (16) for plasma power supply cover
Plasma power supply exterior, rear
Exterior, rear for Powermax SYNC
Item
Part number
Description and kit contents
1
428352
Kit: Air filter bowl, polycarbonate (comes with plasma power supply, includes the O-ring but not the filter element)
011124
2*
428415
Kit: Air filter bowl, nylon (optional – for work sites with oily air) (includes the O-ring but not the filter element)
011128
3
228695
Kit: Air filter element and O-ring (compatible with both filter bowl types)
011093
Air filter element
011125
O-ring
4
428685
Kit: Gas inlet fittings
015145
British Pipe Thread adapter G-1/4 BSPP with 1/4 NPT threads
015337
Industrial interchange quick-disconnect nipple with 1/4 NPT threads
027055
Silicone lubricant, 0.25 ounces
   *   The polycarbonate filter bowl that comes with the plasma power supply is compatible with most gas supply systems, but it is important to keep the gas line clean. Organic solvents, chemicals, cutting oil, synthetic oil, alkali, and thread lock solutions can cause damage to the polycarbonate filter bowl over time. You can use the optional nylon bowl (428415) if conditions at your work site make it difficult to prevent harsh chemicals from getting into the gas line.
Power cord and strain relief
Power cord and strain relief for Powermax SYNC
Item
Part number
5
228885
Kit: Powermax105 SYNC power cord with strain relief, CSA models, 3 m (10 foot)
229443
Power cord assembly 105 A CSA
108697
Strain relief
104675
Aluminum locknut
5
228886
Kit: Powermax105 SYNC power cord with strain relief, 230 V – 400 V CE models, 3 m (10 foot)
229449
Power cord assembly 105 A, 230 V – 400 V CE
108691
Strain relief
104675
Aluminum locknut
6
428949
Kit: Powermax105 SYNC power cord with strain relief, 380 V CCC / 400 V CE models, 3 m (10 foot)
429052
Power cord assembly 105 A, 380 V CCC / 400 V CE
108795
Strain relief
104629
Strain relief adapter
075819
Aluminum washer
7
228915
Kit: Strain relief for Powermax105 SYNC power cords, CSA models
108697
Strain relief
104675
Aluminum locknut
7
228913
Kit: Strain relief for Powermax105 SYNC power cords, 230 V – 400 V CE models
108691
Strain relief
104675
Aluminum locknut
8
228914
Kit: Strain relief for Powermax105 SYNC power cords, 380 V CCC / 400 V CE models
108795
Strain relief
075819
Aluminum washer
Rear panel
Rear panel for Powermax SYNC
Item
Part number
9
528006
Kit: Powermax105 SYNC plasma power supply rear panel with screws and CPC port cover
010586
Label: Protect earth
075807
Screw: M5 X 16, flat head (3)
101197
Plasma power supply rear panel
108867
CPC port cover
210008
Label: Power switch 105 A
CSA, CE, or CCC data plate for Powermax105 SYNC (preapplied)
Plasma power supply interior, rear
Interior, rear of Powermax SYNC
Item
Part number
1
228644
Kit: Powermax65 SYNC power switch CSA
005257
Power switch
075760
Screw:#8 X 1/2, flat head (4)
108858
Power switch handle
110711
Label: Power switch 65 A/85 A
1
228655
Kit: Powermax85 SYNC power switch CSA
003206
Power switch
075760
Screw: #8 X 1/2, flat head (4)
108858
Power switch handle
110711
1
228671
Kit: Powermax65/85 SYNC power switch CE/CCC
005650
Power switch
075760
108858
Power switch handle
110711
1
228879
Kit: Powermax105 SYNC power switch CSA and CE 230 V – 400 V
003206
Power switch
075760
108858
Power switch handle
210008
1
228880
Kit: Powermax105 SYNC power switch CE 400 V / CCC 380 V
005257
Power switch
075760
108858
Power switch handle
210008
Plasma power supply interior, fan side
Interior, fan side of Powermax SYNC
Item
Part number
1
428942
Kit: Air filter assembly (includes air filter, air filter bowl, air filter element, and O-ring)
429017
Air filter assembly
104990
Tubing: 8 mm outer diameter X 1.75 inches
104487
Tubing: 8 mm outer diameter X 3.3 inches (optional – not shown)
2
528053
Kit: Solenoid valve (includes gas tubes and screws)
429061
Solenoid valve
101508
Bracket
104488
Tubing: 5/16 inch outer diameter X 7.75 inches
104632
Tubing: 5/16 inch outer diameter X 12 inches
104990
075711
Screw: M4 X 12, pan head
3
528017
Kit: 90° gas tube fitting
015921
4
528065
Kit: Powermax65/85/105 SYNC Gas tubes
104487
104488
104632
104990
Fan and fan shroud
Fan and fan shroud for Powermax SYNC
Item
Part number
5
428992
Kit: Powermax105 SYNC Fan assembly
429072
Fan assembly
075650
Screw: M4 X 0.7 X 16-9, pan head (3)
6
228910
Kit: Powermax105 SYNC Fan shroud
101199
Fan shroud
Plasma power supply interior, front
Interior, front for Powermax SYNC
Item
Part number
1
528026
Kit: Control PCB and adjustment knob
141472
Control PCB
108797
Adjustment knob
075418
Screw: #4 X 1/4, pan head (3)
2
428068
Kit: Ribbon cable for control PCB, 14 cm (5.5 inches)
223024
Ribbon cable that connects the control PCB to the DSP PCB
3
428070
Kit: Powermax65/85 SYNC work lead receptacle
228364
Work lead receptacle
3
228912
Kit: Powermax105 SYNC work lead receptacle
228800
4
528024
Kit: Powermax65/85 SYNC torch quick-disconnect receptacle
229884
Torch quick-disconnect receptacle housing
015920
075899
Retention nut
075693
Screw: #6 X 1/2, pan head (4)
108076
Grommet
4
528025
Kit: Powermax105 SYNC torch quick-disconnect receptacle
229885
015920
075899
Retention nut
075693
Screw: #6 X 1/2, pan head(4)
108076
Grommet
Front panel
Front panel for Powermax SYNC
Item
Part number
5
528005
Kit: Powermax105 SYNC plasma power supply front panel with screws
002540
Gasket: LCD 65 A/85 A
075807
Screw: M5 X 16, flat head (2)
101063
Panel: Lens 65 A/85 A/105 A/125 A
101459
Panel: Plasma power supply front
210570
Label: Display panel 105 A
210596
Label: Hypertherm logo
Plasma power supply interior, power PCB side
Interior, power PCB side for Powermax SYNC
Item
Part number
1
228705
Kit: Powermax65/85 SYNC component barrier
1
228895
Kit: Powermax105 SYNC component barrier
2
528029
Kit: Powermax65 SYNC power PCB CSA
075534
Screw: #6 X 5/16, pan head (4)
141440
Power PCB, 65 A CSA
2
528030
Kit: Powermax65 SYNC power PCB CE/CCC
075534
141477
Power PCB 65 A CE/CCC
2
528031
Kit: Powermax85 SYNC power PCB CSA
075534
141443
Power PCB 85 A CSA
2
528032
Kit: Powermax85 SYNC power PCB CE/CCC
075534
141453
Power PCB 85 A CE/CCC
2
528033
Kit: Powermax105 SYNC power PCB CSA
075534
141458
Power PCB 105 A CSA
2
528034
Kit: Powermax105 SYNC power PCB CE 230 V – 400 V
075534
141409
Power PCB 105 A CE 230 V – 400 V
2
528035
Kit: Powermax105 SYNC power PCB CE 400 V / CCC 380 V
075534
141460
Power PCB 105 A CE 400 V / CCC 380 V
Capacitors and DSP PCB
Capacitors and DSP PCB for Powermax SYNC
Item
Part number
3
428066
Kit: Power PCB capacitor
075569
Screw: M6 X 14-12.5, pan head (2)
075570
Screw: M5 X 14-12, pan head (2)
109930
Capacitor: 3uF, 850 VDC
4
528028
Kit: DSP PCB
075766
Screw: M3 X 16, pan head (2)
108855
2-pin jumper (preinstalled on PCB)
141421
DSP PCB
210775
Label: “Save system data before you install this part” (not shown)
5
228683
Kit: Powermax65 SYNC bulk capacitor CSA
075570
Screw: M5 X 14-12, pan head (4)
109935
Capacitor: 2200uF, 500 VDC (2)
5
228684
Kit: Powermax65 SYNC bulk capacitor CE / CCC
075570
109947
Capacitor: 3300uF, 400 VDC (2)
5
228681
Kit: Powermax85 SYNC bulk capacitor CSA
075570
109797
Capacitor: 3300uF, 500 VDC (2)
5
228682
Kit: Powermax85 SYNC bulk capacitor CE / CCC
075570
109948
Capacitor: 4400uF, 400 VDC (2)
5
228888
Kit: Powermax105 SYNC bulk capacitors CSA and CE 230 V – 400 V
075567
Screw: M6 X 16-12.5, pan head (4)
209016
5
228889
Kit: Powermax105 SYNC bulk capacitors CE 400 V / CCC 380 V
075567
Screw: M6 X 16-12, pan head (4)
209017
Capacitor: 5200uF, 400 VDC (2)
Plasma power supply interior, heatsink
Part number
Description
128836
Thermal grease, 0.125 ounce
105 A heatsink diode bridges
105 A heatsink diode bridges for Powermax105 SYNC
Item
Part number
1
228902
Kit: Powermax105 SYNC output diode bridge
209027
Output diode bridge (2)
075569
Screw: M6 X 14-12.5, pan head (6)
075851
M6 X 18.5±0.5-12.5, pan head (4)
128836
2
528048
Kit: Powermax105 SYNC input diode bridge
209174
Input diode bridge
075567
Screw: M6 X 16-12.5, pan head (2)
105 A heatsink IGBTs and thermal sensor
105 A heatsink IGBTs and thermal sensor for Powermax105 SYNC
Item
Part number
3
528044
Kit: Powermax105 SYNC pilot arc IGBT
109319
Pilot arc IGBT
223739
Pilot arc cable
075570
075851
Screw: M6 X 18.5±0.5-12.5, pan head (2)
128836
4
528046
Kit: Powermax105 SYNC inverter IGBT
209445
Pilot arc IGBT
223738
PFC IGBT cable (2)
075569
Screw: M6 X 14-12.5, pan head (3)
075851
Screw: M6 X 18.5±0.5 12.5, pan head (4)
128836
5
428990
Kit: Thermal sensor (switch)
209569
Transducer
075524
Screw: M5 X 16, pan head
075851
6
528047
Kit: Powermax105 SYNC PFC IGBT, CSA and CE 230 V – 400 V
109802
PFC IGBT
223738
PFC IGBT cable (2)
075567
075569
128836
IGBT tester
Part number
Description
128883
IGBT tester
105 A heatsink resistors
105 A heatsink resistors for Powermax105 SYNC
Item
Part number
7
228898
Kit: Powermax105 SYNC snubber resistor, 15 Ω, 200 W
209045
Snubber resistor, 15 Ω, 200 W
108868
Standoff (2)
075526
Screw: M4 X 10, pan head (2)
128836
8
228693
Kit: Snubber resistor, 5 Ω, 120 W, CSA and CE 230 V – 400 V
109799
108868
Standoff (2)
075526
128836
9
228894
Kit: Damper resistor, CSA and CE 230 V – 400 V
229458
Damper resistor
075529
Screw: M3 X 10, pan head (2)
128836
10
228897
Kit: Powermax105 SYNC snubber resistor, 5 Ω, 200 W
209044
Snubber resistor, 5 Ω, 200W
108868
Standoff (2)
075526
128836
Power supply interior, magnetics
Power supply interior, magnetics for Powermax105 SYNC
Item
Part number
1
228661
Kit: Powermax65 SYNC PFC inductor CSA
014345
Inductor: PFC
075697
Screw: M5 X 0.8 X 10-10, pan head (2)
1
228670
Kit: Powermax65 SYNC PFC inductor CE / CCC
014348
Inductor: PFC
075697
1
228668
Kit: Powermax85 SYNC PFC inductor CSA
014337
Inductor: PFC
075697
1
228664
Kit: Powermax85 SYNC PFC inductor CE / CCC
014341
Inductor: PFC
075697
1
228873
Kit: Powermax105 SYNC PFC inductor CSA and CE 230 V – 400 V
014353
Inductor: PFC
075569
1
228874
Kit: Powermax105 SYNC PFC inductor CE 400 V / CCC 380 V
014357
Inductor: PFC
075569
2
228663
Kit: Powermax65 SYNC transformer CSA
014346
Transformer
075697
2
228669
Kit: Powermax65 SYNC transformer CE / CCC
014349
Transformer
075697
2
228667
Kit: Powermax85 SYNC transformer CSA
014338
Transformer
075697
2
228654
Kit: Powermax85 SYNC transformer CE / CCC
014342
Transformer
075697
2
228871
Kit: Powermax105 SYNC transformer CSA and CE 230 V – 400 V
014354
Transformer
075569
2
228872
Kit: Powermax105 SYNC transformer CE 400 V / CCC 380 V
014358
Transformer
075569
3
528036
Kit: Powermax65 SYNC output inductor
014439
Output inductor
075697
3
528037
Kit: Powermax85 SYNC output inductor
014440
Output inductor
075697
3
528038
Kit: Powermax105 SYNC output inductor
014441
Out put inductor
075569
Accessories
Hypertherm cartridge reader
The Hypertherm cartridge reader provides a simple process for reviewing data stored in Hypertherm cartridges. Data analysis helps customers understand cartridge utilization and identify operator training opportunities.
Read more
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Read more
Robotic torch clamp kit
The robotic torch clamp kit is designed to simplify integration of Powermax® robotic torches on robots. The clamp fits perfectly with the torch dimensions and securely holds the torch during cutting applications.
Read more
Field service bulletins (10)
Showing 10 of 10 documents
Showing of 10 documents
Show all
Technical support
