Interactive manuals now available
Find answers quickly to your installation, troubleshooting questions, and more. Select a manual.
Operator and instruction manuals (15)
Showing 15 of 15 documents
Showing of 15 documents
Show all
Service manuals (3)
Showing 3 of 3 documents
Showing of 3 documents
Specifications
Cut and gouge capacities
Cut capacity Thickness Cut speed
Recommended 20 mm (3/4″) 500 mm/min (20 ipm)
  25 mm (1″) 250 mm/min (10 ipm)
Severance (hand cutting) 32 mm (1-1/4″) 125 mm/min (5 ipm)
Pierce* 16 mm (5/8″)
*Pierce rating for handheld use or with automatic torch height control
Gouge capacity Metal removal rate Groove profile
Typical gouge 4,0 kg (8.8 lbs.) per hour 2,9 mm D x 6,4 mm W (0.11″ D x 0.25″ W)
General specifications
Specifications - CSA
Input voltages (± 10%)
200–480 V, 1-PH, 50/60 Hz
200–600 V, 3-PH, 50/60 Hz
Input current @ 9 kW
200/208/240/480 V, 1-PH 52/50/44/22 A
200/208/240/480/600 V, 3-PH 32/31/27/13/13 A
Output current
20–65 A
Rated output voltage
139 VDC
Duty cycle @ 40° C (104° F)
50% @ 65 A, 230–600 V, 1/3-PH
40% @ 65 A, 200–208 V, 1/3-PH
100% @ 46 A, 230–600 V, 1/3-PH
Open circuit voltage (OCV)
295 VDC
Weight with 7.6 m (25′) torch
27.8 kg (61.7 lbs.)
CSA – for use in the Americas and Asia, except China
Specifications - CE/CCC
380–400 V, 3-PH, 50/60 Hz
380/400 V, 15.5/15 A
Output current
20–65 A
139 VDC
50% @ 65 A, 380–400 V, 3-PH
100% @ 46 A, 380–400 V, 3-PH
295 VDC
270 VDC
24.1 kg (52.7 lbs.)
CE – for use in Europe, Australia & New Zealand - RCM, Serbia, UK – UKCA, Ukraine, and other countries where accepted. CCC – for use in China.
Dimensions with handles
483 mm D; 233 mm W; 430 mm H
(19″ D; 9.2″ W; 17″ H)
Gas supply
Clean, dry, oil-free air or nitrogen
Recommended inlet gas flow rate
Cutting: 210 I/min @ 5.9 bar (450 scfh, 7.5 scfm @ 85 psi)
Gouging: 210 I/min @ 4.8 bar (450 scfh, 7.5 scfm @ 70 psi)
Electrical efficiency
91.2%
Recyclability
100%
Warranty
Power supply: 6-year
Torch: 1-year
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
CARTRIDGE-65-Drag-Fine-Hand
Drag cutting and FineCut for hand torches
Hypertherm cartridges
Process
Cartridge
65 A
428931
45 A
30-45 A FineCut® hand cutting
Drag cartridge:
FineCut cartridge:
CARTRIDGE-65-Mech-standoff-Fine
Process
Cartridge
65 A
428930
45 A
FineCut® mechanized cutting
Ohmic ring kit
428895
CARTRIDGE-65-MaxControlRemoval-Mech
Process
Cartridge
Max removal gouging 45–85 A
428932
Max control gouging 45–85 A
428933
CARTRIDGE-65-FlushCut
FlushCut
Process
FlushCut™
65 A
428952
CARTRIDGE-65-HyAccess
HyAccess cartridges
Process
HyAccess™
Drag cutting 65 A
428984
Gouging 65 A
428987
Mechanized cutting 65 A
528079
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Plasma power supply exterior, front
Powermax65/85 SYNC power supply exterior, front
Item
Part number
Description
1
528009
Kit: Powermax65 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528010
Kit: Powermax65 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
1
528011
Kit: Powermax85 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528012
Kit: Powermax85 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
1
528013
Kit: Powermax105 SYNC plasma power supply cover with labels, CSA (no screws included)
1
528014
Kit: Powermax105 SYNC plasma power supply cover with labels, CE/CCC (no screws included)
2
428143
Kit: Adjustment knob only
3
428141
Kit: Replacement screws (16) for plasma power supply cover
Plasma power supply exterior, rear
Powermax65/85 SYNC power supply exterior, rear
Item
Part number
Description and kit contents
1
428352
Kit: Air filter bowl, polycarbonate (comes with plasma power supply, includes the O-ring but not the filter element)
011124
2*
428415
Kit: Air filter bowl, nylon (optional – for work sites with oily air) (includes the O-ring but not the filter element)
011128
3
228695
Kit: Air filter element and O-ring (compatible with both filter bowl types)
011093
Air filter element
011125
O-ring
4
428685
Kit: Gas inlet fittings
015145
British Pipe Thread adapter G-1/4 BSPP with 1/4 NPT threads
015337
Industrial interchange quick-disconnect nipple with 1/4 NPT threads
027055
Silicone lubricant, 0.25 ounces
   *   The polycarbonate filter bowl that comes with the plasma power supply is compatible with most gas supply systems, but it is important to keep the gas line clean. Organic solvents, chemicals, cutting oil, synthetic oil, alkali, and thread lock solutions can cause damage to the polycarbonate filter bowl over time. You can use the optional nylon bowl (428415) if conditions at your work site make it difficult to prevent harsh chemicals from getting into the gas line.
Rear panel
Powermax65/85 rear panel
Item
Part number
9
528001
Kit: Powermax65/85 SYNC plasma power supply rear panel with screws and CPC port cover
010586
Label: Protect earth
075524
Screw: M5 X 16, pan head (2)
101033
Plasma power supply rear panel
104497
Self adhesive foam strip
108867
CPC port cover
110711
Label: Power switch 65 A/85 A
CSA, CE, or CCC data plate for Powermax65 SYNC or Powermax85 SYNC (preapplied)
Plasma power supply interior, rear
Powermax65/85 SYNC interior, rear
Item
Part number
1
228644
Kit: Powermax65 SYNC power switch CSA
005257
Power switch
075760
Screw:#8 X 1/2, flat head (4)
108858
Power switch handle
110711
1
228655
Kit: Powermax85 SYNC power switch CSA
003206
Power switch
075760
Screw: #8 X 1/2, flat head (4)
108858
Power switch handle
110711
1
228671
Kit: Powermax65/85 SYNC power switch CE/CCC
005650
Power switch
075760
108858
Power switch handle
110711
1
228879
Kit: Powermax105 SYNC power switch CSA and CE 230 V – 400 V
003206
Power switch
075760
108858
Power switch handle
210008
Label: Power switch 105 A
1
228880
Kit: Powermax105 SYNC power switch CE 400 V / CCC 380 V
005257
Power switch
075760
108858
Power switch handle
210008
Plasma power supply interior, fan side
Powermax65/85 SYNC interior, fan side
Item
Part number
1
428942
Kit: Air filter assembly (includes air filter, air filter bowl, air filter element, and O-ring)
429017
Air filter assembly
104990
Tubing: 8 mm outer diameter X 1.75 inches
104487
Tubing: 8 mm outer diameter X 3.3 inches (optional – not shown)
2
528053
Kit: Solenoid valve (includes gas tubes and screws)
429061
Solenoid valve
101508
Bracket
104488
Tubing: 5/16 inch outer diameter X 7.75 inches
104632
Tubing: 5/16 inch outer diameter X 12 inches
104990
075711
Screw: M4 X 12, pan head
3
528017
Kit: 90° gas tube fitting
015921
4
528065
Kit: Powermax65/85/105 SYNC Gas tubes
104487
104488
104632
104990
Fan and fan shroud
Powermax65/85 SYNC fan and fan shroud
Item
Part number
5
428991
Kit: Powermax65/85 SYNC Fan assembly
429078
Fan assembly
075693
Screw: #6 X 1/2, pan head (4)
6
228694
Kit: Powermax65/85 SYNC Fan shroud
101030
Fan shroud
Plasma power supply interior, front
Powermax65/85 interior, front
Item
Part number
1
528026
Kit: Control PCB and adjustment knob
141472
Control PCB
108797
Adjustment knob
075418
Screw: #4 X 1/4, pan head (3)
2
428068
Kit: Ribbon cable for control PCB, 14 cm (5.5 inches)
223024
Ribbon cable that connects the control PCB to the DSP PCB
3
428070
Kit: Powermax65/85 SYNC work lead receptacle
228364
Work lead receptacle
3
228912
Kit: Powermax105 SYNC work lead receptacle
228800
4
528024
Kit: Powermax65/85 SYNC torch quick-disconnect receptacle
229884
Torch quick-disconnect receptacle housing
015920
075899
Retention nut
075693
108076
Grommet
4
528025
Kit: Powermax105 SYNC torch quick-disconnect receptacle
229885
015920
075899
Retention nut
075693
Screw: #6 X 1/2, pan head(4)
108076
Grommet
Interior, front panel
Powermax65/85 SYNC interior, front panel
Item
Part number
5
528000
Kit: Powermax65/85 SYNC plasma power supply front panel with screws
002540
Gasket: LCD 65 A/85 A
075524
101063
Panel: Lens 65 A/85 A/105 A/125 A
101460
Panel: Plasma power supply front
104497
Foam: Close cell black
210569
Label: Display panel 65 A/85 A
210596
Label: Hypertherm logo
Plasma power supply interior, power PCB side
Powermax65/85 SYNC PCB side
Item
Part number
1
228705
Kit: Powermax65/85 SYNC component barrier
1
228895
Kit: Powermax105 SYNC component barrier
2
528029
Kit: Powermax65 SYNC power PCB CSA
075534
Screw: #6 X 5/16, pan head (4)
141440
Power PCB, 65 A CSA
2
528030
Kit: Powermax65 SYNC power PCB CE/CCC
075534
141477
Power PCB 65 A CE/CCC
2
528031
Kit: Powermax85 SYNC power PCB CSA
075534
141443
Power PCB 85 A CSA
2
528032
Kit: Powermax85 SYNC power PCB CE/CCC
075534
141453
Power PCB 85 A CE/CCC
2
528033
Kit: Powermax105 SYNC power PCB CSA
075534
141458
Power PCB 105 A CSA
2
528034
Kit: Powermax105 SYNC power PCB CE 230 V – 400 V
075534
141409
Power PCB 105 A CE 230 V – 400 V
2
528035
Kit: Powermax105 SYNC power PCB CE 400 V / CCC 380 V
075534
141460
Power PCB 105 A CE 400 V / CCC 380 V
Capacitors and DSP PCB
Powermax65/85 SYNC capacitors
Item
Part number
3
428066
Kit: Power PCB capacitor
075569
Screw: M6 X 14-12.5, pan head (2)
075570
Screw: M5 X 14-12, pan head (2)
109930
Capacitor: 3uF, 850 VDC
4
528028
Kit: DSP PCB
075766
Screw: M3 X 16, pan head (2)
108855
2-pin jumper (preinstalled on PCB)
141421
DSP PCB
210775
Label: “Save system data before you install this part” (not shown)
5
228683
Kit: Powermax65 SYNC bulk capacitor CSA
075570
Screw: M5 X 14-12, pan head (4)
109935
Capacitor: 2200uF, 500 VDC (2)
5
228684
Kit: Powermax65 SYNC bulk capacitor CE / CCC
075570
109947
Capacitor: 3300uF, 400 VDC (2)
5
228681
Kit: Powermax85 SYNC bulk capacitor CSA
075570
109797
Capacitor: 3300uF, 500 VDC (2)
5
228682
Kit: Powermax85 SYNC bulk capacitor CE / CCC
075570
109948
Capacitor: 4400uF, 400 VDC (2)
5
228888
Kit: Powermax105 SYNC bulk capacitors CSA and CE 230 V – 400 V
075567
Screw: M6 X 16-12.5, pan head (4)
209016
5
228889
Kit: Powermax105 SYNC bulk capacitors CE 400 V / CCC 380 V
075567
Screw: M6 X 16-12, pan head (4)
209017
Capacitor: 5200uF, 400 VDC (2)
Plasma power supply interior, heatsink
You can purchase thermal grease separately.
Part number
Description
128836
Thermal grease, 0.125 ounce
65 A / 85 A heatsink diode bridges
Powermax65/85 SYNC diode bridges
Item
Part number
1
228803
Kit: Powermax65 SYNC output diode bridge
109804
Output diode (2)
075567
128836
1
228804
Kit: Powermax85 SYNC output diode bridge
109980
Output diode (2)
075567
128836
2
228742
Kit: Powermax65 SYNC (all models) and Powermax85 SYNC CE / CCC input diode bridge
109931
Input diode bridge
075524
075570
Screw: M5 X 14-12, pan head (5)
128836
2
228741
Kit: Powermax85 SYNC CSA input diode bridge
109801
Input diode bridge
075524
075570
128836
Power supply interior, magnetics
Powermax65/85 SYNC interior, magnetics
Item
Part number
1
228661
Kit: Powermax65 SYNC PFC inductor CSA
014345
Inductor: PFC
075697
Screw: M5 X 0.8 X 10-10, pan head (2)
1
228670
Kit: Powermax65 SYNC PFC inductor CE / CCC
014348
Inductor: PFC
075697
1
228668
Kit: Powermax85 SYNC PFC inductor CSA
014337
Inductor: PFC
075697
1
228664
Kit: Powermax85 SYNC PFC inductor CE / CCC
014341
Inductor: PFC
075697
1
228873
Kit: Powermax105 SYNC PFC inductor CSA and CE 230 V – 400 V
014353
Inductor: PFC
075569
1
228874
Kit: Powermax105 SYNC PFC inductor CE 400 V / CCC 380 V
014357
Inductor: PFC
075569
2
228663
Kit: Powermax65 SYNC transformer CSA
014346
Transformer
075697
2
228669
Kit: Powermax65 SYNC transformer CE / CCC
014349
Transformer
075697
2
228667
Kit: Powermax85 SYNC transformer CSA
014338
Transformer
075697
2
228654
Kit: Powermax85 SYNC transformer CE / CCC
014342
Transformer
075697
2
228871
Kit: Powermax105 SYNC transformer CSA and CE 230 V – 400 V
014354
Transformer
075569
2
228872
Kit: Powermax105 SYNC transformer CE 400 V / CCC 380 V
014358
Transformer
075569
3
528036
Kit: Powermax65 SYNC output inductor
014439
Output inductor
075697
3
528037
Kit: Powermax85 SYNC output inductor
014440
Output inductor
075697
3
528038
Kit: Powermax105 SYNC output inductor
014441
Out put inductor
075569
Machine interface and RS-485 serial interface upgrade kits
Powermax65/85 SYNC RS485 interface
Item
Part number
Description
1
228539
Kit: Serial interface receptacle with internal cables and RS-485 serial interface PCB
2
228697
Kit: Machine interface receptacle with internal cables and voltage divider PCB for Powermax65/85 SYNC (does not include cover for receptacle)
2
528045
Kit: Machine interface receptacle with internal cables and voltage divider PCB for Powermax105 SYNC (does not include cover for receptacle)
3
128650
Remote start pendant for machine torch, 7.6 m (25 foot)
3
128651
Remote start pendant for machine torch, 15 m (50 foot)
3
128652
Remote start pendant for machine torch, 23 m (75 foot)
3
428755
Remote start pendant for machine torch, 46 m (150 foot)
428975
Kit: Replacement switch for remote start pendant (not shown)
4
127204
Cover for machine interface receptacle
External cables for machine interface receptacle and RS-485 serial interface receptacle
Powermax65/85 SYNC machine interface cables
Hypertherm offers a variety of external cables that connect to the machine interface receptacle and the RS-485 serial interface receptacle. For setup information refer to the Powermax65/85/105 SYNC Mechanized Cutting Guide (810480).
Machine interface cables
Item
Part number
Description
1
023206
External machine interface cable*, 4 spade connectors, 7.6 m (25 foot)
1
023279
External machine interface cable*, 4 spade connectors, 15 m (50 foot)
2
228350
Kit: External machine interface cable**, 6 spade connectors, 7.6 m (25 foot)
2
228351
Kit: External machine interface cable**, 6 spade connectors, 15 m (50 foot)
3
223354
External machine interface cable**, D-sub connector with screws, 3.0 m (10 foot)
3
223355
External machine interface cable**, D-sub connector with screws, 6.0 m (20 foot)
3
223048
External machine interface cable**, D-sub connector with screws, 7.6 m (25 foot)
3
223356
External machine interface cable**, D-sub connector with screws, 10.7 m (35 foot)
3
123896
External machine interface cable**, D-sub connector with screws, 15 m (50 foot)
4
223733
External machine interface cable† for mechanized cutting systems with a 21.1:1 voltage ratio (for example, PlasmaCAM® systems), 6-pin DIN connector, 4.6 m (15 foot)
4
223734
External machine interface cable† for mechanized cutting systems with a 21.1:1 voltage ratio (for example, PlasmaCAM® systems), 6-pin DIN connector, 6.0 m (20 foot)
   *   Communicates start, stop, and arc transfer signals. Uses an external voltage divider PCB.
   **   Communicates start, stop, arc transfer, and divided arc voltage signals. Uses the internal voltage divider PCB.
   †   Communicates start, stop, and divided arc voltage signals. Uses the internal voltage divider PCB.
RS-485 serial interface cables
The RS-485 serial interface cables communicate information for controlling operating mode, amperage, and gas pressure and control mode.
Item
Part number
Description
1
223236
External RS-485 cable, unterminated, 7.6 m (25 foot)
1
223237
External RS-485 cable, unterminated, 15 m (50 foot)
2
223239
External RS-485 cable, 9-pin D-sub connector for Hypertherm controls, 7.6 m (25 foot)
2
223240
External RS-485 cable, 9-pin D-sub connector for Hypertherm controls, 15 m (50 foot)
Accessories
Hypertherm cartridge reader
The Hypertherm cartridge reader provides a simple process for reviewing data stored in Hypertherm cartridges. Data analysis helps customers understand cartridge utilization and identify operator training opportunities.
Read more
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Read more
Robotic torch clamp kit
The robotic torch clamp kit is designed to simplify integration of Powermax® robotic torches on robots. The clamp fits perfectly with the torch dimensions and securely holds the torch during cutting applications.
Read more
Cartridge ohmic ring: #428895
The ohmic contact ring clips onto the mechanized cartridge, and connects it via electrical wire to torch height controls (THCs) that support the use of ohmic contact to find the surface of the workpiece before each cut.
Read more
Field service bulletins (10)
Showing 10 of 10 documents
Showing of 10 documents
Show all
Technical support
